The Throttle Cable jams on if I apply too much pressure, quite embarrasing in traffic!
Just a case of replacing or tightening the cable or could there be more of a problem? is replacing the cable an easy enough job?
Also recently I am losing quite an alarming amount of power steering fluid, I can see where the leak is its just beside the front drivers side wheel and appears to be coming from where the pipe joins the unit rather than a split in the pipe itself.
Is this a common problem?
