Hi Sam - yes, the early models are somewhat different from later models and are VERY prone to electrical issues....... I know as I have a few gremlins of my own ! This really sounds as if it's heat related - classically a break in a lead giving trouble when heated up and recovering as it cools down. The DME temp sensor on the front of the block is a common culprit but this really only ultimately alters the mixture. Have you checked the connections to the crank sensor (s) at the back of the block per sulzeruk's post (he knows what hes talking about......) ? Probably worth testing the LT side from battery to coil when the engines hot, if not already checked out, and I reckon you need to retest everything when hot regardless, as this is where your fault lies [&:] Whereabouts in the country are you - perhaps one of us is close by and could lend a hand ?
