sam116glan
Hello anyone who can help
I am quite knowledgeable about cars in general but have no experience of the porsche 944.
This is the situation. I bought the car which had been standing for a few months and was not firing on no 3 cylinder. This was sorted by taking out no 3 injector it was bunged up with crap and after cleaning out the car started and ran perfectly for about 8 minutes. This is what I have done since following forum and manual advice etc.
The car is early 1985 2.5 ltr.
Fuel pump relay changed.
Fuel pump connections jumped All fine.
Fuel Pump pressure checked at the rail ok
Fuel filter changed.
Fuel tank drained flushed and new petrol.
Battery voltage checked at all the recomend positions from the manual. 12 volts at coil etc.
Coil changed
Distributer cap changed
Rotor arm changed.
This is the interesting part.
When left overnight the car starts fine & runs for about 5-8 minutes then cuts out due to lack of H.T. spark (checked with strobe light and can be seen stuttering then stopping)
Will not start again for about 15mins then will run for about 30 seconds
Leave for an hour or 2 will run for about 2-3mins then cuts out.
Next day starts fine and runs for the usual 5-8 mins.
One thing I haven't checked yet is the oxygen sensor in the manifold do you think this could cause these symptoms?
I await your suggestions
Sam
Coil changed
Rotor arm changed.
Sam
