Most suitable home charger
petercook
PCGB Honorary Member
Hi Guys,
In the process of looking for a Taycan. Not had an electric before so do not have a home charger, any recommendations? Reports on the Porsche unit suggests a number of issues, the reports on the Andersen unit [Andersen now official installers for Porsche unit] suggests aftersales is poor? Open to advice.
Hi Peter,
Unfortunately I can’t answer your question but I assume that the 12V auxiliary battery will be a lithium-ion type and there are a number of well-know manufacturers such as Ctek who can supply an appropriate device.
However I’m interested to know why with an EV you would need a battery conditioner when surely the car's internal software will manage the 12V battery by topping it off using the main high-voltage traction battery? Unless of course you’re planning to lay-up the car for extended periods of time??
Good luck with your search … I’m sure that that there are a lot of well-spec’d Taycans around at bargain prices ATM!?
Jeff
Hi Jeff,
I'm after advice on a home wall charger [7 kW} to charge the EV battery pack, not a battery conditioner.
Peter
Ha,ha! Apologies Peter … clearly I was on the wrong track totally!?
I’ve not yet taken the EV route but my friend recently purchased a Skoda Elroq RS and got a [discounted Ohme Home Pro or similar?] charger through his electricity supplier Octopus. After a few initial handshaking issues he’s been very happy with the set-up which includes cheap electricity even during the day at times with their smart charging system.
I’m sure that it’ll be worth talking to your own supplier to see what’s on offer.
Jeff
Relative has an Anderson EV charger, uses it for several makes of EVs; and says installation and after sales service has been good. Had it for over 2 years and they had to replace the cable that connects charger to car and promptly responded and fixed fault.
Also sent the following discount link for Anderson EV chargers:
I went for the Ohme. Easy to use, syncs with the car, great app and excellent customer support. Its a very small unit as well (I didn't go for the one with the captive lead) so its not an eyesore attached to the house. Synced with Octopus Intelligent Charging to get the best rate during the night.
