more horses
- Thread starter craig
What model of 944 are you talking about: a 2.5 Lux?
Suffolk944
Moderator
I've never ever heard of it being done on a 944.
Erm, where do I start?ORIGINAL: craig
nitrous
Please tell me your name isn't really >whispers< Brett ... [
I would be interested in understanding why this mod is done and what it brings to the car. I have also not heard of it being done to a 944.
It's simple, cheap and not very difficult. The hardest part of a nitrous conversion is getting the extra fuel in there and controlling the whole thing correctly.
The simplicity and cheapness, and the fact that it can be readily bolted onto pretty much any engine, makes it appeal to those who want more power cheaply. Nothing wrong with that per se, but it does seem to appeal particularly to the go-faster crowd who quite like their bolt-on modifications and outrageous power claims.
And, before you know it, you end up with something looking like this:
Peter Empson
ORIGINAL: craig
hello all...sorry im a novice,i was told that my 944 1984 2.5 four cylinder had carbouretors..i know virtually nothing about engines,ill get a chip fitted and a stainless exhaust...can i fit it with nitrous then ,,,,hahaha...joking,,,,but can i?????
First things first, probably best to get your car on a dyno, it wont cost much and will tell you where you currently are. If the power is down from factory specs then simple maintenance will be money well spent. You are very unlikely to find any real peak power gains with a chip (and even less with an exhaust in my opinion), but the driveability will increase with the former so the car will often feel newer and more perky.
If you really want to go a lot quicker then stripping the car is the way to go, a proper engine rebuild could net you a bit more but will be costly. Changing the anti roll bars (to those taken from a late turbo) and fitting some better brake pads will make it a lot more fun (unless you're only interested in straight line speed). Nitrous never appealed to me, would get fed up refilling it, and don't expect the transmission to last long, they're the weakest part of the car.
Suffolk944
Moderator
Craig, there's a fairly recent thread over on TIPEC with a guy looking to add nitro to his S2 which may or may not prove helpful to you.
sawood12
A 944 turbo with a good NOS setup would be a very interesting prospect. With a huge turbo and a bit of clever programming you could use the NOS to combat the turbo lag and when the turbo came on song you're really take off.
pauljmcnulty
ORIGINAL: craig
hey chaps thanks for the replies, all taken in...someone mentioned that i could maybe fit a super charger to her as well...or rather than a turbo,,any comments on that,,,
Rewind to your first post, read the replies and insert "supercharger" for "carbs". [
Peter Empson
ORIGINAL: craig
You certainly can supercharge it, if you're able to diy it then I'd say go for it, possibly can just be done for about £1,500 with used parts, but that's very much a guess. If buying an existing kit then it's likely that it will be much cheaper to buy an S2 or turbo, both of which will have more power than an SC'd Lux.
dave364634
nos is useless unless you go to santa pod (n2o is expensive, insurance will more than double).
get a chip is you want, but the non turbo 944 engines don't seem that tuneable, and a 2.7 / 3.0 swap would be better. an LS swap would be best.
DivineE
BUY A TURBO! £1500 944 lux + £1000 inevitable new owner costs + £1500 wasted on silly tuning ideas over 6 months trying to gain 10hp = £4000 = Turbo money.
Chipped 220 turbo = 280hp plus 300+ torques thats a gain of nearly 150hp! ..and you get a free brake/chassis upgrade to go with it! It's a deal, its a steal, its the sale of the something century.
