Mobile Porsche mechanics ..Middlesex / Surrey
Do you have the replacement belt sensor?
If not, generally cheapest from OPC (with PCGB discount)
It's an easy DIY job, undo the single bolt fastening (#4 in the attached diagram) the unit, don't need to remove belts, lift towards you and disconnect connection plug. Then refit in reverse order.
Thanks but I cant get to the bolt there virtually no space to get in an undo it with the tools I've got ......
