Misfiring 991 997.1
Please can someone help!!!. My porsche 911.997.1 2007, keeps misfiring, the garage has checked for bore score, changed the timing chain, replaced a bent valve, replaced the wiring loom, spark, plugs coil pack have all been changed, it's been going on for 3 years. I'm going crazy. Please help !!!
Where are you
Are you using a reputable Indy (or OPC)
Members on here will advise of their local indy. If its been going on for 3 years you should have tried a different on 2 years ago.
Is it actually a Indy that is known for Rear engined Porsches
Lots of thing - wondering what damage could have been caused bu a bent valve (And what caused it )
Where the correct Plugs and Coil packs fitted and TIGHT
Fuel Filter ?
Run a tank full of V Power through
Lots of thinks
Where are you going tomorrow
You can buy a Analyster yourself
If you wre in West London go to AMS Porsche, in Hertfordshire How much have you spend on FUEL over the last 3 years - Best it something really simple
I had a 986.1 Boxster son in law change the plugs and Packs (I always do my own maintenance) after 4 months it started occasional miss fires (Eventually turned out to be a loose coil pack )
Good Luck
Any news on your car @brian.pilgrim
Yes hi red 997! You wouldn't believe it . Rsr porsche/ yonter asim has swapped my 3.8 engine for a 3.6. This came to light when 911 sbd, who are carrying out the work ordered the parts and none of them was compatible. I've reported it to the police, they seemed keen on the uptake. They went to yonter asims garage. It's been repossessed. All his mobile numbers are changed. The have downgraded the crime as a fraud. And told me if I want to pursue him I must do so through the civil courts. Now as things stand I'm looking for a 3.8 engine. They aren't cheap 😪😪
That's horrendous!!! I wish you the best of luck with recovering what you can. I imagine there will be a long list of debtors. I guess an option is the get an engine with bore score and get it rebuilt. I know it's expensive but you'll remove the worry of future problems. My regular mechanic, Angus Archer of AMS Porsche, who I suggested up thread, has very sadly passed away. He was an absolute gentleman and would have been able to assist you but sadly the business the business is closed, at least temporarily. I'm now on the look out myself for another decent independent.
Yes I heard 😪😪😪rip Angus, I 911 sbd was due to pick up a engine from Angus last week. And was greeted with the sad news. Puts everything into prospective really. Life is so fragile
Where are you
Fuel Filter ?
Lots of thinks
If you are in West London go to AMS Porsche, in Hertfordshire How much have you spend on FUEL over the last 3 years - Best it something really simple
Good Luck
Same here with my 987 Son in Law Fitted new Coil Packs - Occasional misfiring
Eventually blew the engine trying to clear the fault Sold the car to someone who wanted a project car to fit a A6 twin
He came back to me and said Yes it was a loose Coil pack despite me asking a qualified mechanic to check them He said it will not be that when I suggested it
So everyone ALWAYS check those coli packs Maybe tighten Maybe replace - it did not shpw up in checker
