Miles per gallon
- Thread starter beeRS
944 man
pauljmcnulty
If you mean a full tank, check your fuel lines aren't leaking. Calculate the actual MPG though, as the guage is so hoplessly inaccurate that you might have only used three-quarters of a tank. A lux should hover around the 30 MPG mark in general, careful driving. It plummets when pushing hard, high motorway speeds or heavy traffic, of course. I used to get to around 360 miles in VJ before I worried about filling up, and often 400 and never ran out. I don't know whether the tanks are the same size in a 2.7?300 miles from a full tank on my 2.7 and I don't have a particularly heavy right foot. Does this sound right?
MRGT
Outrun944
I'm wondering this ... in my manual for my 1984 LUX it states (from memory as I don't have it to hand here) "only use 98 RON petrol" What are peoples thoughts on this? Is there any issue or worry about using standard 95 RON? Is there any real benefit in performance and economy when using above 95 RON? (incidentally I've got quite a way over 300 miles on my 2.5L tank) Cheers!ORIGINAL: ChasR I rarely put in 98RON into my 944 (Is there much benefit to running it on 98? I know manual says 95 is fine...). Last time I filled up the tank to the brim I hit around 350 miles to the tank.
morris944s2john
david924s
pauljmcnulty
That's low, but it's so hard to judge as we've no real clue as to the sort of journies you do, or how you drive. It's winter, which makes a slight difference, and as mentioned a good service will improve things. As will tyre pressures. All I can say is that my Lux very rarely went less than 30MPG on a tankful, if ever. That included a good mix of urban short runs, A-road blasts and motorway driving at a healthy cruising speed, probably as near to an average useage as you would get. I'm not heavy-footed, but it was always driven "enthusiastically", and often on runs would be in convoy with the Turbo boys, so I was always playing catch-up to an extent. The one really bad mileage I got was almost no miles to a full tank. That was the fuel line giving up, though. Worth checking.I've calculated my MPG to be 23.5 - not great .
andy watson
Moderator
I paid that for tesco 99 today [&:]ORIGINAL: sc0tty Don't worry lads, petrol will be £1.20 a litre next week !!![]
DivineE
That's because you drive like a girl[8D]. Get a turbo that'll soon stop you measuring! I can watch the fuel gauge move on full boost[ORIGINAL: zcacogp My S2 driven conservatively on moderate journeys can provide an average of 28-29mpg across a tank - that's getting to 400 miles between fill-ups on a regular basis.
