lowering springs
- Thread starter Guest
sawood12
You have to consider doing something with your front control arm ball joints if you are lowering significantly.
Peter Empson
The Lux's nose is higher off the ground so speed bumps are much less of a problem than on S2's and Turbo's, so that's one blessing (I'm lower than -30mm now and have only ever caught the exhaust/sill on a particularly unpleasent road into an industrial estate (funnily enough where my car is being restored, so I don't know how I'm going to get it out without damaging it when it's done [
chrisg
Secondly, IMHO, aftermarket lowering springs can be overpriced and won't always take into account the needs/ lb/ft compression rates you need for any particular car.
My advice for what it's worth, speak to coil springs in Sheffield who will custom make/ design you a set 0114 2758573,
C
944 man
sawood12
KW seems expensive and is a bit of a leap of faith, but in reality it is not expensive. It totally and utterly transforms the feel and capability of the car and steps things up a good couple of notches. For such a night and day step change improvement the cost of the install is very reasonable indeed. Much more cost effective and sensible than frittering away many pounds at a time chasing horses.
Suffolk944
Moderator
ORIGINAL: sawood12
Half the cost of my KW install was the labour and parts related to the removal of the axel and the re-indexing. Whenever you remove a major part of the car there is always the 'while you're in there' jobs that you really must do. Having said that, afterwards, knowing what was done had been done provided a nice comforting and reassuring glow.
My car is currently having KW's fitted at Promax (along some other jobs) and am really looking forward to experiencing the difference it makes when she emerges from the workshop. She has already been lowered so I am hoping that any further re-indexing won't be needed. Will be looking to sell on the 968CS M030 suspension that is coming off the car should anyone be interested.
Suffolk944
Moderator
sawood12
ORIGINAL: Suffolk944
ORIGINAL: sawood12
If they set the car up like they did mine (i.e. with a nose down attitude) be careful of two things - firstly make sure they adjust the headlights afterwards as they will be pointing down at the ground and will be useless in the dark, and I found the front to be a bit too low and subsequently raised it to flatten off the car a bit with no noticable detriment to the handling of the car - i'd advise this setup rather than the nose-down attitude.
I'd definately look to sorting something out with the front wishbones. There have been too many people with lowered cars suffer failed A-Arms. It is a definate threat and needs to be addressed. The Rennbay geometry correcting kit works fine.
smiffyraf1
TTM
Well-known member
ORIGINAL: smiffyraf1
will lowering springs designed for a turbo fit an 88 2.5? simple and short![]()
944 turbo 220 and late non-turbo 944 springs are swappable, so if the springs you have in mind come from a turbo 220 then the answer is yes.
smiffyraf1
