Hairyarse
Well a bit of an update so far. The crank bolt wasn't finger loose at least, it seems tight but I will check the torque on it just to be sure.
I removed the OPRV and it's the old 3-piece type.
Worryingly when I went to undo it I didn't need any force - I couldn't unscrew it with my fingers at any point when trying to take it out but I needed very little force applied to the ratchet so maybe it wasn't tight enough in the first place? It wasn't leaking any oil out though.
I'm going to turn the eninge over with the valve out to check oil is coming out, re-insert it, check the crank pulley bolt then run the engine again to see if it's cured. Maybe the OPRV has just had it, I've read that the springs can go weak over time
