Low beam issue
lee.jackson
Hi
Changed the passenger side low beam bulb today as it was not working. Still not working. Used the correct Bosch replacement bulb. Only the passenger side. I have checked all connections are clean. Xenon for main driving lights working fine. Wondering if anyone is this great knowledge pool has any insight? Any advice appreciated
Remove the lamp unit and check that none of the pins inside the connector on the unit have bent or broken.
Had similar on a 986 and was wiring on back of connector unit inside the headlight unit. Removed the headlight unit, unscrewed the connector from back of headlight unit, checked continuity with a multimeter and found bad connection, cleaned contact and soldered it for longer life. Reassembled and all good.
Hope this helps.
