Lose Inner Wing Cover - A piller (Left & right)
DenAtherton
Hi
I have a 2018 991.2 C4S
The Inner plastic A pillar covers (part number 991 504 641(2) 00 1EO) are held on with 2 x Black Pastic Rivets
both have worked loose. Very tricky to access (its those pastic covers that when you open the door - and put you hand into the gap
under the A pillar.
Is there a way to replace these 2 x Black rivets without removing the doors?
Den Atherton
Some rivets have a two tier top, so the very top part of it can be prised or pulled out/up and it releases the grip inside the panel. Some don't though and are pulled out and flexible ribs which aren't damaged with removal/refitting. This type has a solid head and not a head made of two parts. Hopefully that makes? You might have to bite the bullet the and simply pull one out using a couple of screwdrivers and some tape or material to protect the surfaces you see. Once out either google it and head to Ebay where most clips/rivets etc are obtainable OR head to an OPC.
