Load Cover Handle
neal.lynch
Hello, I recently purchased a Panamera outside of the Porsche network and have noticed that one of the handles is missing from the load cover.
Photo of the one that is fitted and where the missing one should be.
Can anyone let me know where I could get a replacement?
Many thanks
Many thanks
Which model of panamera is yours
Suggest download the parts diagram for your model and see if it's available as a separate part.
If available as a separate part probably cheapest from your OPC and check if different colour codes when ordering and ask for PCGB discount.
If not available as a separate part you may be able to get a replacement one made by 3D printing company.
Otherwise try online (eBay, etc) for complete cover with handles or damaged cover that you can remove the handle from.
Looking at the parts diagram they aren't available separately and if you want a new load cover...I hope you're sitting down, they are £700 plus VAT
Dan
Dan
Thanks Dan,
I was fearful I may have to ‘assume the position’!
3D printing route it is then!
Possible, it's a common part across VW group and may be able to get a used VW / Audi / Skoda / Seat cover just for the handle(s).
Good luck
I have managed to remove the existing one which has revealed what I think are part numbers.
9918022220
9918022184
9918022185
A while to update.
I found someone local to me who does 3d printing as a sideline.
Took the remaining handle to him and he has re-engineered the original and they have come out brilliantly.
Significantly cheaper than a new cover and a lot less hassle than trawling eBay and breakers.
He is up for all sorts of printing so if you have a need reach out to Andrei his website is: https://ak3dstudio.com/
Hello, I recently purchased a Panamera outside of the Porsche network and have noticed that one of the handles is missing from the load cover. background photo edit
Many thanks
You can get a replacement from a Porsche dealer or OEM parts website—just make sure to match the part number and interior color for your Panamera.
