Scott it doesn't use the O2 sensor on mine because I don't have one. If you have an O2 sensor it does use it to give you an idea of where you are when tuning and it is easy to see from within the Vitesse software exactly where you need to be leaner or richer. I have a Wideband sensor which is much more accurate but is not tied into the Vitesse software so you have to log a run on the Wideband, study the results and then apply changes to the Vitesse. It sounds 'bitty' but in practice is very simple.
This is a picture of the Map screen. Again it looks confusing but once you see it in action with the car running it is very simple. The deflection scale along the bottom shows the air being measured by the MAF according to your throttle position. The scale up the RH side is the RPM range that you are currently at. As you drive along a red cursor moves around the cells and you just increase or decrease the fuel in each cell until the Wideband reads what you want it to.
On a WOT run the cursor moves almost straight to the 75% column and climbs up that side to max RPM. On a part throttle or cruise mode it hovers around the 4 cells slap bang in the middle of the grid. My next step is to tune those cells so that I get a fuel effecient 14.5:1 during 'normal' driving [
"He who goes looking for flames will find flames. But he will also find trouble soon after."
