LHD > RHD headlamps question
- Thread starter RSGulp
pncarrerars
Pete 964 RS
lee fulford
This year it effectively failed on the the beams.........How do you work that one out then? [&:]
jamescharnley
Dave Wilkinson
The reality is that LHD and RHD headlamps ARE different - it's not just the lenses. If you get an MOT tester who is a stickler for the rules he will fail a car with RHD lenses on LHD headlamps because the beam pattern is completely screwed. The same argument is true if you have beam deflectors fitted.
That is not to say it will be failed by all testers. It's very much pot luck dependent on where you go, how well you know them and, probably, how much persuasion you can employ to get your certificate!!!
Personally I went the route of getting complete headlamps - others may make their own choice.
Dave
jamescharnley
