Well, finally getting to use the extended warranty - a slow coolant leak and a minor oil leak means a fairly substantial engine strip down and new gaskets I guess.
Over the last few months the coolant level light has come on needing a good top up. The OPC couldn't find anything at the last warranty check and since moving house my new local OPC has serviced it and cleaned off the underside of the engine to try and trace the cause. Back today with the warning light on, 2k miles since the service, and sure enough tell tale signs on the bottom of the crankcase with the shroud stripped off. Also a minor oil leakage in the same area. Hopefully a fix for both in a couple of weeks time.
