short backstory -
~12 months ago gearbox replaced with recon unit.
~6 months ago intermittent knocking/clicking from O/S rear. lasts 1/2 hr then disappears. happens 3-4 times.
~2 months ago noise gets persistent after ~20 mins driving. jiggling o/s driveshaft stops it temporarily.
today i took the O/S driveshaft off. CV's seem ok - telescope in and out smoothly, no radial play.
does this grease look new? wondering as i was told they had been repacked when I reported the fault last service;
also there is lateral play in the axle stub at the gearbox, is this normal? not much, about 1 mil;
the sound when moving it is just like the one i've been hearing while driving.
I suspect the CVs are ok and that the gearbox has play and is starting to vibrate when hot. I'm a bit paranoid that way though. im hoping that repacking/repalcing the CVs will cure it but hoping someone can shed light on the play in the gearbox.
cheers
cheers
