Key fob signal weak
- Thread starter Simbob997
kasspa
I have recently replaced both my key heads on my '04 996 4S, at a price, as 1 was intermittent & the other had stopped working completely.
I think you will just have to bite the bullet & do likewise.
There was someone on here recently claiming that they can 'fix' them but I'm sure if OPC's & Indies can't then you know the saying; if it sounds too good to be true.....
[URL=https://www.porscheclubgb.com/forum/tm.aspx?m=1013972]https://www.porscheclubgb...orum/tm.aspx?m=1013972[/URL]
See link above which includes my posts re key fob
Hope this helps
Paul
Simbob997
Thank you for the post, I have found my issue I believe [
I have a Bluetooth device that I have plugged into my cigarette lighter in the centre console which allows me to play music from my phone onto my radio. Once this is removed hey presto the key fobs work again from a good distance, must have been blocking the signal somehow!!!!
Hope this might help others with a gen 1 car and the same set up!!!
Si
