Just a wee tale .... 2.5 8V Restoration
- Thread starter PAUL RUDDY
h4x0r7000 said:Any updates?
At the moment I am cleaning the engine block with a toothbrush.......
Its these hidden costs that mount up in restorations, the steel alone is £200 plus I am getting a fabricator in to do the welding after I have measured, cut and prepped everything.....shouldn't have sold my welder !!
The frames will be available when I've finished with them.
All the best, Paul
944 man said:Even Ken is looking at this and thinking: sh*t! Im cutting corners! []
Lol, I very much doubt it...
A few small updates.
I finished my frames to move the bare shell about on so the car is now mobile again, in a Flintstone style.
The n/s front wing is back from investigatory media blasting, the news is good, just a couple of pinholes and it's now with the bodyshop for MIG brazing, once this is back and fitted there's a wee bit more cleaning to do where access was restricted by the axle stands, door handles etc to remove, then I'll be talking to the bodyshop about a slot for some India Red.
I've also been stripping the engine/clutch down for inspection and replacement.....and cleaning with toothbrushes.
All the best, Paul
Not a lot left
Kongsodoken
just been and brought an electric tooth brush to catch up
fantastic work ......great motivation to finish the house and get back on to the car
Kongsodoken said:just been and brought an electric tooth brush to catch up![]()
That made me chuckle.....and gave me ideas
944 man
Kongsodoken said:944 man said:Even Ken is looking at this and thinking: sh*t! Im cutting corners! []
I used to refer to a job done properly as 'The Full Ken', but in light of Paul's spectacular effort I have now changed this to 'The Fully Ruddy'.
He used to do this in his sleep to early Ford RS models and his known all over for his work.
when this is done I need to drop my turbo off with him and tell him to give me a call when it's done.
He knows and I know he gets more of a buzz doing the resto than driving the things, and good on him.
924Srr27l
PAUL RUDDY said:I also completed the conversion of the front struts to Bilstein inserts
It may be too late now? but the Top screwable cap that Bilstein supply must be bare metal
with no coating at all.. and really needs Paint or clear Lacquer.
(although you may never see them under the Blue covers)
Here's what mine look like after fitting only 3 months ago.. All furred up with rust
R
All the best, Paul
TTM said:Just curious why the bare aluminum parts were painted instead of cleaned?
They have been vapour blasted
924Srr27l
Cleaned / blasted / stripped in acid all produce the same results, although the high pressure water (Posh name - Vapour) blasting leaves a uniform flat sheen on the metal which looks clean & great has no protection at all and will corrode.
Most metalwork on all car's has to be covered, coated, painted, plated etc..
otherwise in time and (dependent on use & conditions) all the nice clean bare aluminium will look like this..
R
