It's never just one problem is it...
- Thread starter pauljmcnulty
pauljmcnulty
Only na, na, na na na, told you so. [unless anyone has any other comment or advice before I order a replacement
peanut
is the ignition amplifier heatsink bolted tight to the wing to dissipate heat ? might pay to bed it in some thermal transfer paste. look on the bright side Tref ,when it runs at least you can brake the car when you need to ![ORIGINAL: tref The S2 died on me again on Saturday - . My immediate suspect is the ignition amplifier I recently fitted. The heatsink does get quite warm - just about as hot as you can continuously keep you hand against it. Anyone with an S2 know if this is normal or not? TIA, Tref.
peanut
thats the ticket Tref ,lateral thinking....[ORIGINAL: tref So between us, we have one S2 that doesn't stop, and one that doesn't go... if we put the two together, we could build one good one that didn't stop or go![:-]
VanhireBoys
And us Irish are a nation of tractor mechanics and "it will be grand" thinking My thoughts are the fuel pressure valve on the return line to the tank (does an S2 have one ?) I had a 9000 Saab a long time ago and the valve jammed shut not allowing any fuel back to the tank ! The fuel pressure was through the roof and the only place for it to go was the combustion vhamber... Massive amounts of fuel were being injected in and flooding the cyclinders... You said the fuel pressure climbed and then she woulnt start ! After she throws a fit check the plugs for wetnessORIGINAL: peanut Us Brits can't be deterred by a few minor setbacks ....we are inventors....a Nation of shed-people. []
peanut
Luckily I am half Irish so I always think it will be grand as I work on my tractor in my shed lol[ORIGINAL: VanhireBoys And us Irish are a nation of tractor mechanics and "it will be grand" thinking
peanut
