Hi All,
Had a problem starting recently so got battery and alternator checked and both were OK. So only thing to check is loose connections/bad earth/starter motor. Can anyone advise on the positioning of the starter and is it easy to get at??? The problem seems to have gone away at present so i suspect dirty solenoid or motor brushes as the car does not get used enough[&:] but i would like to check the wiring and maybe have the starter off for a check.
Ian
Ian
