Is my OPC ripping me off?
I made a separate post about my failed sports exhaust valve. The metal bracket that works one of the vacuum actuators snapped. This is a well known fault and there are many posts on failed sports exhausts. I have the extended Porsche warranty and in the past, these have always been covered by the warranty. I took my car to my local OPC that said it was caused by corrosion and therefore not covered by the warranty.
The quote for replacing half the exhaust was £3,600. I was also told that the price for retrofitting a whole exhaust was £2,500. I don't understand how the cost for half an exhaust can be so much more than a whole exhaust?
After much complaining, I have been offered a goodwill payment but only in respect of the £3,600 quote. The OPC and Porsche GB have offered to contribute £3,000 and want me to pay the balance of £600 and they will replace half the exhaust. Should I take up their offer?
If a better quality material was used when the car was designed & assembled then corrosion would not be an issue. Same problem as the 3 exhaust flange bolts completely corroding then shearing.
If a better quality material was used in the first place ,corrosion would not be an issue. Same as the 3 exhaust flange bolts which have a funny habit of dissolving & then the exhaust spilts completely.
There are several weak spots on the Boxster as you say, I've been through the triangle of bolts already, (and a numbers of other things too (987.2) but it is also the same on my 1973 911, but not in such numbers.
All cars have something somewhere, modern ones have more due to more complex designs and functions, BUT, you pay a lot for a Porsche and expect a robust design, made to last and be reliable.
Can't help but think not enough is done at the design stage.
All about costs. 2010/2011 cars feel much better built and engineered to me.
Then VAG took over and it will went down hill. Now Porsche change the warranty so you cannot claim either !!
In 20 years modern cars of this era will be worthless imo. NOT fixable and junk.
