Interment Starting issue
Tricky__D
Hi, looking for some recommendations / suggestions please. I have a 1998 Carrera Coupe Manual and am suffering from an intermittent start issue. Can go for ages where it starts on the button, but then sometimes work start. When I say won't start, I mean that the ignition lights are on, the key turns, but no cranking. Up to now I have replaced the ignition switch, starter relay and starter motor and was working fine last year, but I put it away, when the salt appears on the road. However, it happened again this morning when getting it ready for its MOT, left it for 20 mins, went back and it started and continues to start every time. It happens when hot or cold before and after journeys and is doing my head in. Fault reader shows no trouble codes.
Would welcome any suggestions or any recommendations of a Porsche independent near Worksop / Doncaster area as I need to get this fixed.
Thanks in advance.
Richard
Hi Richard,
It sounds as though you could have an earthing problem with the starter motor or perhaps an issue with the motor itself.🤔
I would think that any garage should be able to help, but you could try Googling to see if there are any Porsche Independents in your area.
Good luck!
Jeff
There's 2 Earth leads I think. 1 at the battery and 1 at the engine
It's drivers side engine (flywheel end) to body , about 12" long , they can frey badly especially if motor mounts are worn but you can't see because of the heatshrink covering it up where the cable enters the ferrule. I've just made a new one for mine.
Starter is earthed to the block and then via this cable to the body and to the battery - .
Is there a switch on the clutch on those which won’t allow the starter to turn unless the clutch is fully depressed? If so, worth replacing. I had identical issues on my new 2009 Cayman S. Replaced 2 switches under warranty. OPC struggled to diagnose because diagnostics showed no errors and no “depress clutch pedal” messages on dash which it should have done. Not sure if 996 has such a switch - somebody will know!
