Interior Temp Sensors..?
zwhitea
Can anyone help with the following.. On my 87 Carrera there is what looks to be the start of an internal temp sensor between the steering column and the heater controls, which then runs down to the actual sensor, behind the ashtray.. Is this what it is..? If so is there a way of testing it..?
The interior heat sensor is behind a small, circular plastic plate, with 2 horizontal slots, next to the slider controls. This connects by plastic tube to the sensor itself, next to the ashtray. This sensor should read 1.9K ohms at 20 Celsius.
I assume that yours is faulty, hence the question. There is also a sensor on the heat exchangers, both of which feed the between seats control unit, via cables.
All of this I have gleaned from the fact that I have a 87 3.2, and own the Bentley book. I can give more clues (removal/testing/ etc.), if required.
Hi there,
your quest re the temp sensor. What is wrong with your heating system?
I have made/created replacement bits for this sensor, and have written an article on same. (yet to give it to someone to publish)
Give me a yell if you need further help.
Peter[:D]
Thanks for your help... I' m not actually sure there is anything wrong with the heating system, other than, it doesn' t shut off 100%, but i' m sure thats just the control boxes after after the heat exchangers..
I' ve owned the car for about a year, during which have spend loads on repairs etc.. I' m now just trying to ensure that all the remaining bits and bots are fully working..
PS.. would you recommend getting hold of the Bentley book..?
