interesting turbo engine build
- Thread starter 944Turbo
Assuming he's on the standard Turbo gears and final drive, it's geared for 190 mph at 7500 rpm, and with 676 bhp at those revs it will get there in a big hurry.
Be interesting to see how it holds together.
TTM
Well-known member
I would be curious to know the levels of air intake temperature measured, maybe not too much if the intercooler is drowned in cold water like is the case with most proper engine dynos, but it may be a different kettle of fish when the IC is on the car, exposed to "only" the flow of ambiant air.
This engine would certainly enjoy a bigger turbo such as a GTX3582R to run that much boost in a more comfortable fashion.
I would love to see his dyno and ign charts. Running 32psi on pump fuel is pretty unconventional. Sure, the 16v heads are more resistant to knock but this is certainly pushing the boundaries. Not sure how long the 265mm rears will last. [
edh
ORIGINAL: Diver944
He's been posting about it on Tipec for a few weeks. It is very interesting and a fresh idea to the way most would soup up a 944T. I want to see how it goes when installed to a car and how it copes with the heat generated at that boost
yes - heat is the issue (unless all he wants to do is drive it up a ¼ mile). I used to get heat soak & rising temps after 20-30 mins on track on a hot day running 26/8 at 15psi.
TTM
Well-known member
ORIGINAL: 333pg333
Perhaps the lack of preconception might have allowed him some more freedom from the normal attitudes regarding these motors.
The turbos he mentioned testing are certainly excellent choices for the 2.0L Cosworth engines he has a background with.
I'm really hoping he will be motivated enough to try some larger ones. I reckon there is the potential to go beyond 750bhp here, well at least on a engine dyno.
George Elliott
Cosworth engineering technology is right up there, the merc 190 16v, and audi rs4 benefitted from it with impressive results, but for me they tend to apply their expertise to fragile ford engine platforms.
I realise turbotim3 is not Cosworth but is very familiar with their technology. Interestingly, he seems to like the m44/xx engine and has certainly made it rev. Those boost numbers are off the scale of what we are familiar with. (unless the wastegate jams shut [8|])
Well done Tim, have a word with Stefan Rosser, and lets have a "White Bird" video to superseed Yellowbird at the ring.
George
944t
I look forward to reading your comments.
Cheers Tim
TTM
Well-known member
You really don't want to have too much low and mid range torque, which in my case was a pain on the road as it required much effort and restrain to keep the car at reasonable speeds, until a I eventually fitted a short runner intake maniold.
As you know the engine will be peakier with a larger turbo but it's crying for it and it should also be a lot more fun than a flat torque curve, which will put more strain on the drivetrain.
ORIGINAL: TTM
The way I see it is that you have been looking for making a high-revving engine from the start (16V + short stroke), so why not slap a larger turbo, have a reasonably peaky engine feeling like a normally-aspirated one?
Hi revving or not I still think it is going to make too much torque for the drivetrain whenever it comes in...at those boost levels.
In actuality the power figures you've reached already will be too high for general use, but it's great to see what you can do on the engine dyno. I agree with Thom that a larger turbo will make a better choice for a few reasons. As mentioned on your Tipec thread, you can build a simple brace between the rear of the gearbox across to the chassis and restrict the lateral movement which has proved to be effective in reducing the amount of cracked CVs on the US cars who tend to drag race. I've done similar just as insurance. The rather expensive LR axles and CVs ($1200 pair!) are rated at high levels of tq but I'm not risking anything. My usage won't include hard starts so that's a bonus. Not sure, but I don't get the impression you're building this for drag racing or even traffic light racing Tim.
I think you'll need more rubber and better suspension. As most in here would agree, the KW offerings work very well on these cars. You can run up to 11" wide rears with a bit of creativity but I ran 10" all round easily. Just need the right offset. Looking forward to your next results. [
TTM
Well-known member
ORIGINAL: nick_968
Sure, whence trying a larger turbo to lower mid range torque and getting about the same hp with less boost. To me it would be a win-win situation.
George Elliott
firstly, don't blow the head off it. give it to me....[
but seriously, from what you have posted, it is a very unique 944 turbo engine configuration, look after it.
As Patrick said - the answer to your question is it depends...on how you drive it. As you will know a car with 200hp is more fragile than one with 85hp, and that potential for damage increases as power increases.
Some people could drive your 500+ horse car for 50,000 miles and it would only need oil and tyres, others could break it inside 100 miles.
My experience with a much lesser (300 and a bit hp car) is that the running gear is exceptionally well engineered. The Clutch, Torque tube, transmission, diff, trailing arm units, are very durable. Of these the Diff is weakest, followed by the clutch, rough changes will knacker the 'box obviously. You will get some rear wheel steer under power at your levels, the VW type 2 descended rear end is good but you are asking a lot of it.
I would keep to 9" rear rims to let the pressure off the transmission. I can imagine two black parallel lines will be a frequent sight in the rear view mirror. Your car in the dry, would be like mine in the wet. [8|]
IF, you really want a solution, there is one, - it will spoil the character but make the worlds fastest 944t, find yourself an R35GTR transmission and 4 driveshafts.......[8|]
Good luck
George
944t
