indicators wont cancel
- Thread starter Guest
The stalk module is clamped to the steering column & needs to be adjusted fore-aft to get the indicator cancel lined up. I removed the wheel and the plastic cover immediately behind the wheel, and loosened the clamp bolt (under the column, screw head is on the right) so I could move the stalks back & forth but it was stiff enough to stay where it was put.
Put the wheel back on & pull the stalks towards the wheel then back off a gain just enough so the wheel doesn't scrape as you turn it.
Remove the wheel again, tighten up the clamp & reassemble. It may be possible to get to the clamp without removing the steering wheel, I haven't tried.
