Fat Albert
My old girl has always been a bit leaky, and apart from the cam cover I have always taken the view that a pint of oil every couple of weeks is much cheaper than actually trying to fix all the leaks
However, of late the leaks have become progressively worse so have been having a poke around underneath to see if I can see where it is all coming from, unfortunately in doing so I found a loose connection on my oil pressure sender and when I went to finger-tighten it the connection stud came off in my fingers...so if anyone has a spare or can point me in the direction of the cheapest new ones that would be appreciated, are they easy to change?
So, the two main leaks i have found are this one:
this is directly under the front main pulley and is a continuous stream when the engine is running, is this just the plate on the front or is it something more sinister like the front main seal?
The second one is from somewhere around where the filter screws in, I can see and feel lots of hot oil around there, but can't see where it is comeing from, any likely culprits that anyone can suggest?
What is the big 28mm bolt you can see below the pressure sender? I am not sure if it is weeping, or oil is driipping onto it from above...
She has a lot of miles to do this month as I have to run around having Christmas lunches with my clients, so in the short term I will just have to keep topping her up and carry a can in the boot and hope that it doesn't get catastrophic!
Any hints or tips would be greatly appreciated!
