robwright
Stuart I am presuming that Al still has not installed the correct chip after rebuild for your set up after it failed after engine rebuild? If this is the case then there is no point diagnosing anything until you have the correct chip installed for your setup. You can however adjust your idle AFR if you want to. It should be 14.7 on idle which is perfect stoich. I would advise waiting until you have your chip setup correct first before doing this.
