Hairyarse
Ok, so the S2 arrived yesterday [
] http://www.porscheclubgbforum.com/tm.asp?m=606315
Andrew had mentioned there was sometimes an idle problem and there is but not sure where to go with it. The ISV was checked and cleaned not many miles ago, I think Andrew said the O2 sensor was replaced and things generally looked over.
The issue when first collected the car was at times when say idling the revs would go low and it stalls. After a good run yesterday that doesn't happen any more but when you stop the revs drop almost to nothing and 9 times out of 10 it wont stall and revs go back to normal. When driving slow at say 30mph you can feel the engine surging ever so slightly up and down - it's very subtle.
New DME relay is in just to take that out the equation. I looked on line at a test method for the Idle Control Switch - haven't done this yet but my symptoms aren't really the same as described.
Anyone got any other ideas? Vacuum leak?
Andy
Andy
