Hydraulic brake switches
anthony.hunston
'82 911 SC
Hi guys
Both brake light switches are U/S.
How do I access the rear switch? It's obscured by the vent box and I can’t see how to remove the vent box. Any advice / videos would be much appreciated
Tony
Hi Tony,
The piping top left will compress so you can remove it. You see the circular clips. There is one each side so you can take these off with some pliers or mole grip. This splits the parts into two. The bottom part is held on by two screws accessed from inside the car under the dash. Again a fiddly job but improves access. i hope this helps.
Rich
