how many miles is high mileage ?
- Thread starter ocallen
We ran an online poll back in 2003 and most 944's were around the 150k mile mark back then
http://www.porscheclubgbforum.com/tm.asp?m=308&mpage=1&key=poll
Unfortunatley the poll software got corrupted and no-one knows how to fix it [&o]
pauljmcnulty
I'd guess that a carefully driven, regular cruising use, with obsessive oil changes, engine is almost limitless? Wasn't there a Volve P1800 with original engine, clutch etc. in the States with something like 3 million miles on it that had just done constant 55mph use? Most suspension, braking or steer parts are only really subject to type of use and age-related limits, not mileage. Apart from, I suppose, the driver's seat, it could be argued that mileage is far less relevant than any other consideration? [8|]
DavidL
It's had a big top end rebuild but the block should be fine. It certainly goes ok.
I know the oil has been changed regularly as I have the receipts!
simonbrooks
random hero
ORIGINAL: random hero
Ive just bought an 83 car with 144000 miles on it but it's had 23 previous owners which is a record for any car that ive owned !!!
One analogy, whether you consider or not, is that a high number of previous owners is not always a bad thing (probably more so on a car like a 944). If you consider, an enthusiast will tend to throw money at a car they have just purchased to bring it up to spec, so it could be a wise purchase in the long run.
pauljmcnulty
Couldn't agree more. Mine started out as a guy's company car, then he bought it out for his wife, then another family member - all the time servicing it religiously. The next owner spent silly money on paint, teardrops, stereo etc. whilst doing only about 1000 miles each year. Every owner has been fastidious with maintenance throughout it's history, and that at least suggests they weren't idiots thrashing it around.
The thing to avoid is lots of changes of owner in a short period of time, for obvious reasons.
random hero
morris944s2john
http://www.porscheclubgbforum.com/tm.asp?m=422847
random hero
Yes i only bought it for the roof and will break the rest of the car for spares. Its not as bad as 2 halfs welded together but has had the boot floor and back panel off another car stiched into it which wouldnt have been too bad if it was done properly but its a bodge job and the n/s rear quarter is comming away where it joins the back panel !!ORIGINAL: morris944s2john
If its a real "cut n shut" job- i.e. two accident damaged cars welded together crudely, then its a danger to be on the road. Presumably you got it cheap to break for parts?
