How do the courtesy light work?
john.greenfield
Hi Guys, I have a 1988 porsche 911 carrera 3.2 Targa with a few niggly electrical faults. How dose the courtesy light work?
The light works fine manually by toggling the lens, its the auto side via the doors which i need to confirm. Dose the light turn on and off immediately when the door opens or closes or is there any delay in turning off. (i'm trying to verify if there is any connection to a relay)
Many thanks John G
When we owned our 3.2, I had to take out the door switches and play about with them to get them to make a solid contact. They are "push to break" type switches and I think moisture gets into them (from memory) causing corrosion sufficient to stop electrical conduction.
Thanks Nick, yes they can develop a bad connection, my issue is slightly different as the cable to the drivers door "A" pillar is missing but I'm not sure if the light on the 1988/89 G body stays on for a few seconds after the door is closed. A friend has a 1985 and that doesn't but there are a few differences in the cars from 87 on. I appreciate the feedback though thanks JG.
No delay unless an aftermarket item has been fitted that were very popular back in the 90's. Take the light unit out and if fitted it will be wired onto that. 993 have factory delay.
Wires can get twisted and break on the back of the door hinge switch
Thanks for the info the light unit is standard, I'll rewire it with the correct colour code cable and door pillar switches. Many thanks John G
