how do I change the steering wheel??
- Thread starter j4mou
Northern924
944 man
Did you connect the wire to the horn push pad on the original wheel? It runs from the bottom of the original boss section and has a slender Lucar connector on the end. You need to check that the wooden wheel's boss isnt a cheap-type that used the cars horn ring. If theres a brass on plastic ring on the base, held on by three screws then your red wheel isnt going to sound the horn, because the contact is missing. Youll need to swap it over taking care to keep the indicator cancelling cam in the correct orientation.
j4mou
http://www.guardian.co.uk/books/2011/jun/12/terry-pratchett-dignitas-suicide-euthanasia
then id seen this since too, not a nice end
http://www.telegraph.co.uk/news/worldnews/europe/switzerland/7641989/300-urns-with-human-ashes-dumped-in-Lake-Zurich-near-Dignitas-clinic.html
