Took A9 for its MOT today, rather concerned about all the new points (no cat etc - not sure if a 2.7 had one as standard in the UK or not) and the emissions (I seem to have an AFM where the spindle seems to slowly rotate under the force of the spring, so I've no idea whats right of wrong, I just keep the plugs looking the correct colour!), however all these things ok!
2 fails - No plate light! - Was ok last night when I checked it! - Easily sorted.
- Petrol leak! - Appears when playing with gear change linkage last weekend, I noticed the fuel filter was a little loose, so I put a nice big tie wrap on it and pulled it up nicely against the crossmember.
This how ever put a little extra stress on the pipe and union on the pump, pulling it round a little on the banjo joint allowing the leak!
Stripped out pump (and one way valve), how it had moved I dont know, it was all very tight! Cleaned all seal faces and reassembled with new copper washers.
Total cost £45.50, including test, (I had the washers) and 2 hours of my time, not bad for 22+ years and 250 000+ miles.
Did a few other little bit around town and had 3 conversation about how good they are!
