Hot front wings.., is it normal ?
- Thread starter tescophil
One side got hotter than the other, I think that under the front wing is where the AC exchangers are situated, so on a hot day with the AC running you get a build up of heat in the wheel arch area, especially if you don't have much air flow (such as in traffic). The heat goes up and soaks into the wing.
Are the wheels REALLY hot too? If they are I'd go with brakes, if not then it won't be the brakes.
Maybe!
Check you brakes unles you have driven it hard they should not be very hot
If they are that may be your problem
A/C will produce high heat in exchangers especially in this weather (UK)
Also remember you will get water as this is dropped under car
Is A/C working well - make sure all you drain pipes are unblocked - A/C on critical as it will leak into car
