Hi,
I purchased a new Boxster 718 4.0 GTS last year and my local OPC set up everything correctly to enable me to use the My Porsche App on my iPhone to remotely pull back key information from the car (i.e. locked/unlocked status, tyre pressure, trip info etc.).
Unfortunately, I have been plagued with an issue when using (wired) Apple Car Play in that the PCM touchscreen randomly stops working (in Google Maps etc.) and my phone typically has to be unplugged and replugged to correct. I referred this back to the OPC and they in the end fitted a new touchscreen, but pretty soon afterwards the same problem re-occurred.
In trying to resolve this, one of the suggested resolution steps was to manually reset the PCM back to factory settings, which I duly did. This unfortunately did not resolve the touchscreen issue which remains to this day, but that is not the purpose of this post (although any suggestions on this would be greatly welcomed!)
As a result of the reset, I was then required to re-establish all the device connectivity that had been previously configured.
I thought I had done all this successfully, but have realised that whilst the My Porsche App on my phone appears to be remotely connecting to the car, it is not actually pulling back some of the key data that was there originally (i.e. the dynamic information regarding locked/unlocked status, tyre pressures, trip data etc.)
I presume that this means that I need to re-establish the appropriate level of connectivity between the My Porsche App and the car's PCM, but despite going online and following numerous suggested steps, I can't seem to do this. I have double checked that the Privacy setting is set correctly and logged onto the Vehicle's inbuilt Wi-Fi using my phone but cannot seem to find the setting within either the PCM or within the App to re-establish the appropriate level of connectivity between the two of them.
Part of the confusion is that some of Porsche's own help screens still talk about the Porsche Connect app (now discontinued) rather than My Porsche and there are obviously a number of different menu setups dependent on the version of PCM running in the car. Lots of rabbit holes ensue!
Has anyone else encountered this and got any suggestions?
Any help would be much appreciated.
Thanks, Keith
Thanks, Keith
