Help please
- Thread starter blade7
Any clues as to what might be wrong?
thanks for any help
Dont I know it Oli - you wont remember but I had to rebuild the top end of my white car when the timing chain and tensioner failed, 2 brand new cams, a recon head from EMC, water pump and all the bits that go with that lot. Will get new fuel tomorrow and see what happens.ORIGINAL: zcacogp Could be that it's not firing on all cylinders. How old are the spark plugs, HT leads and dizzy cap/rotor arm? (Sadly the last three items are pricey for an S2.) Oli.
Oh loads more than the cost of a decent secon-hand engine but lets not go there. Read the threads and most talk about hot starting, mine is from cold, not got it to run long enough since it happened to get it hot. I have a spare DME and tried that and made no difference.ORIGINAL: zcacogp Ouch - no I don't remember it but that couldn't have been far off the cost of a decent second-hand engine, surely? A bit of a long shot, but there is something odd that occasionally happens to S2's when starting which manifests itself as a misfire. There have been a couple of threads about it within the last year or so, one of which was mine. Here: https://www.porscheclubgb.com/forum/tm.asp?m=778974&mpage=1&key=startingò¾–£ https://www.porscheclubgb.com/forum/tm.asp?m=727042&mpage=1&key=%F2%B1%A0%82 Are you simply suffering a worse version of this? Oli.
