DC911SC
Hi folks, I've just got a 1991 turbo.
Its been sitting quite a while (several years) with a few electrical probs, but is in pretty good nick!
I am putting together a service list to get an order in, I've had 2 NA's before but never a turbo and want to make sure I'm using not only the best but correct parts as I've read a few horror stories.
This is my list, looking for feedback on whether its the right gear or not!
Spark plugs - NGK BPR7ES - use preset gap?
Oil filter / Air Filter / Air Filter all Knecht supplied from CP4L (but are Mann v Mahle v Bosch v Knecht v Hengst which is best??)
Battery - Bosch S3 100 70ah
All belts Timing / Balance / PAS / Alt - All Contitech - is Gates better? (pulleys mainly Febi etc)
Gear box oil? no idea
Coolant - looks like VW red or purple phosphate free?
Missed anything I should change?
Oil I'm not sure what to use read so many threads about ZDDP levels (needing to be over 1500ppm?) a lot of the reading material is American what Brand is best here in the uk - 15w40 rated it looks? I think I'll probably only run the oil for a short period of time and drop it to get everything clean.
So this is all bearing in mind it hasn't ran in a long time. Will drop the fuel and clean the tank filter sort the electrical problems, then flush the cooling system.
