Help! Bonnet & boot releases broken!
- Thread starter colin129
Steve Brookes
Moderator
Rear lid is spring loaded on early 964s. Lots of pressing, pulling and jiggling side to side will see it pop open of it's own accord. Replacing the cable is easy - just attach to the old handle and thread it through.
Steve Brookes
Moderator
ORIGINAL: kevinl
Did I read somewhere once that some models have an emergency engine bay cable behind the nearside light cluster??
Yes, the later models have emergency releases front and rear and will probably be there on your '92. The design of the rear catch was changed so that it doesn't spring open when the main cable snaps. So in that case you have to use the emergency release.
Last year I changed the front cable precisely because of what has just happened to Colin and I fitted an emergency release to the front. I didn't fit an emergency release to the rear because there's no point seeing as I have the earlier spring open catch. I remember Dave Wilkinson's rear cable snapping....initially he couldn't get the lid to open but sure enough when he drove a few miles down the road, it popped open of its own accord.
Here's what I did at the front:
http://forums.rennlist.com/rennforums/964-forum/653054-preventative-maintenance.html?highlight=emergency+release
The engine cover release was just very stiff so a little grease has been applied, I was worried about pulling it too hard in case something terrible happened.
I am using a very local garage called Ninex Motorsport, who run cars in the Club Championship, literally 5 mins walk from my house. I've also asked them to look at the earthing issues. I'll see how it goes & maybe I'll give them my next service.
Steve Brookes
Moderator
turbo jonny
Yesterday i felt like a bit of bonding maintenance and had a go. A bit tricky dismantling the handle ( pin seized)
and routing the new cable back through the rubber grommet at the bulkhead all took longer than expected - about
3-4 hours in all and a stiff back this morning. I ended up attaching a wire to the loop on the cable and pulling it
through the grommet & bulkhead.
Steve Brookes
Moderator
