Help advice needed
944 man
Check Clark's or t'internet for DME relay bridge. Its probably the DME relay, but the fuel pressure regulator is a close second.
To explain: the DMW relay is actually two relays in one case. The first powers the ECU/DME when the ignition is turned on and the second powers the fuel pump when it is turned on by the DME. Its in the fusebox and it says 'DME Relais' on its top. You can buy a new one for under £25 and its never wasted as you should have one in your glovebox, or you can make up a bridge which replaces it in order to rule it out.
ok, Thanks for the quick reply 944 man, will get one to test it out , off topic....... I know you are a Subaru fan so like to let you know that my P1 is back from Prosport with a EJ22 2.35 forged engine install :D
Hi guys, my 944S has not been use for a few weeks ...so went to fire her up last week and its seem to br running rough (SO i THOUGH IT MIGHT BE THE COIL OR LEADS ...easy fix I though )
had abit of time yesterday so though I'll fix it now ...try to start but starter motor turns the engine but will not start , so I thought maybe out of fuel .
earlier today put some petrol in and try to start the engine but not joy , any ideas ??
could it be the fuel pump, fuel pump fuse/relay ?........it does seem to be fuel starvation related
New Ignition coil and amplifier fitted last year so can't be that .
Very nice. Very expensive too I expect. What turbo, boost, ECU, torque, power, etc? I still have an Impreza, but seldom bother with ScoobyNet now.
yr right its been expensive, still have the Lateral MD321T on it atm,engine only just done 60 miles so need to run it in before I get Bob Rawle to tweak the map on the Motec m800 Pro, will expect 460+ bhp at the very least depending on boost settings.
just an update, car is running again ...seems the spark plugs were all oiled up so changed them and all is fine now :D
They shouldn't be like that - suggest you investigate what caused it. No doubt experts reading this can suggest possible causes, but Porsche engines look after their plugs pretty well (spark plugs seem to be the topic-of-the-week!)
well i had recently fitted a reburb airflow meter from Frazerparts and play around with the adjusting screw by the throttle boby to try and correct the erratic idle !
