hello and problems :/
- Thread starter dann944
John Sims
PCGB Admin
Squeaking grinding noises can be many things. If you could give us more information that would help.
Does it only happen while slowing down?
Is it relative to one particular gear?
Does it continue after slowing down?
Is it relative to slowing down using the engine or using the brakes?
Is it when slowing in a straight line or while slowing turning a particular way?
dann944
Dann
pauljmcnulty
ORIGINAL: dann944
coasting and slowing dude, also driveshafts are fine replaced them last month
Did you replace the CV joints though x4 ?
