maritimeblue911
I''m not sure what's left to check..
I have followed the excellent guide on http://www.clarks-garage.com/shop-manual/hvac-01.htm
I cannot get nr 3, control motor for temperature mix flap, to operate; it should move with the temperature control dial - I know the motor itself is fine as when I connect it to the plug for nr 4, it moves with the slider on the Temperature Control Unit. I also know it can get power as when I detach it from its linkage, it twitches for a moment when the ignition is switched on/off.
Meanwhile I know the solenoid for the heating valve (nr 3 in the other picture) switches the vacuum line ok as I can see the heating valve move under the bonnet when I connect +12V to the solenoid (but the valve stays always open otherwise).
I have changed the Temperature Control Unit in the dash for another -admittedly second hand - one, no difference.
I have replaced the interior temperature sensor for another -admittedly second hand- one, no difference.
One thing that's confused me a bit is that the under bonnet heater control valve is located at the front of my engine above the oil filter, when all the references online mention it as being at the back of the engine by the firewall.
