HEATER PROBLEM
- Thread starter Guest
then look under garage manual, then heater for a full decription of a likely problem
Gareth
timig
Sorry to drag up an old thread, but I was wondering if this fairly commen problem can be fixed even if the symptoms occur when the heater/fan controls are all off? My cabin is getting pretty warm at the moment, and I haven't switched anything on! When I do put the fan on to try and cool things down (I know it isnt air con, but I thought it might be worth a try), and it is at its lowest setting, it does seem to blow out warm air?
Thanks in advance.
It's very easy to check your clip:
1. Disconnect the battery (dont shut the boot [
2. Open the glovebox and lower it past the stays so it hangs down around your knees.
3. Undo the 5 (or 6) tiny screws that hold the glovebox liner in place.
4. Slide out the liner towards you and unplug the connector for the light when you can.
The rods and clips will be on the R.H side and you can see them now the liner is out of the way. Try setting the dial to different temperatures and watch how the rod moves
I would just remove the interior light fuse rather than diconnect the battery - in fact I just do it "live" because the glove box liner has been in and out so often I know what to avoid popping the fuse.
sawood12
I phoned him tonight and he said he still couldn't get it to work, so I presume he will have tried all speeds???
Theres a couple more electrical faults (i'll pester you with these later [
Otherwise the car seems a cracker.
Fred Hindle
Good luck with the purchase.
Cheers,
I've spoken to a recomended specialist who also said it may just be the fuse. I can't check till I pick it up tomorrow. It also 'may' be the control panel, which he says would have to be sent away to be repaired.
He's never had to replace a motor due to wear, only for squeaks [>:]
Anyhow, tomorrow I pick up my first Porsche!
ORIGINAL: Fred Hindle
The bullet type fuses are very poor compared to the blade type.
Mine are the blade type.
Well I've had a good fiddle with the fuse and relays, I've given the dash a good wallop and I've wiggled the wires connected to the motor, but the motor has only switched itself on (by itself) on three occasions for a total time of around 10 seconds!
So the motor obviously works on all speeds so what else could it be? When it doesn't work it doesn't work on all speeds, including four.
Also the drivers side window motor is inop but when I push the button in the revs drop, so it must be drawing current, which would suggest the motor is ok???. Any ideas?
Ta
I'm thinking the relay could be a prime suspect, and also it will be the easiest thing to check, if only I had a known working one.
Which brings me nicely to..... Does anyone have a known working one they could loan me? Perhaps post to me? I can return soon as along with a small amount of alcohol tokens [
I've tried ebay. There are various relays but no heater relay.
Its relay number 1 on my 86 turbo. I would imagine they are all the same? Infact I'll update with a pic in a few minutes.
dico4488@yahoo.co.uk
edited with pics (not the best quality)
http://i60.photobucket.com/albums/h38/samdico/TangmereElan023.jpg
http://i60.photobucket.com/albums/h38/samdico/TangmereElan025.jpg
http://i60.photobucket.com/albums/h38/samdico/TangmereElan024.jpg
There are also various numbers written on the sides -
944.615.119.00 899673 12v 30a
Ta, Dico
Black_JPN
http://www.porscheshop.co.uk/acatalog/porsche_944_motors_relays.html
Also - maybe Bert stocks them?
