Heater Blower Fan 955
Beetlebum
Hi folks looking for some advice, suggestions. So I replaced the blower fan and resistor under the passenger side dash, behind the glove box as my original fan was very slow, so having replaced both I start the car it worked fine for a while then nothing then it cuts back in when it feels like, so after a bit more investigation when I disconnect the main blower fan and reconnect at the fan it starts, so I turn off at ignition turn on again whilst going and nothing again, I disconnect and re connect works, off at ignition back on nothing, help required please.
FYI changed the resistor behind the glove box and the fan and resolved the issue but I think the resistor was the problem!
It’s also worth checking for a voltage drop on the supply wire when the fault occurs, and making sure the earth/ground point for the blower circuit is clean and tight. If everything checks out physically, there’s a real chance the new resistor pack or blower is incompatible or faulty out of the box, but more often this behaviour comes down to wiring or a relay that’s sticking or not energising reliably.
FNF​
Hi ?? i did buy a new fan and resistor but ended up using a second hand resistor as it didn’t seem to work, there’s still a small delay to starting when i turn ignition on, you mentioned a relay, where is this located? might be worth changing, i don’t use the car every day sometimes a few days, someone mentioned getting a trickle charger (solar) to keep the car voltage topped up, thanks for your reply.
