Heated Seat not working
Tizzy
Hi all,
i think something similar to this has appeared in the other 911 variant forums - but has anyone experienced heated seat button flashes red briefly and then goes off? - seat heating obviously doesn’t work. Done fuse checks etc and the passenger seat switch and heating works fine. Could it be the under seat connections or a fault on the loom inside the seat? Suggestions very welcome!
Many thanks Chris
Sounds like it might be the control module (relay) in the driver's seat. You could try swapping the unit from the passenger side to see if it works then.
Thanks Richard, where do I find said relay? Presume it’s a remove the seat and it may be underneath?
kind regards
chris
kind regards
chris
Did you get this sorted. Same thing has happened to mine.
Might just be better swapping the seat out for another used one tbh.
