Headgasket going? Symptoms
- Thread starter jmelhuish
sawood12
DivineE
White smoke that lingers from the exhaust (doesn't dissipate like normal morning mist) looks much denser and smells obviously stale/damp
Clean spark plugs that look like they've been cleaned.
Hot running
Heater blowing cold air when set to hot... erm
Misfire when first started and for first couple of minutes... I think that about covers all the symptoms.
pauljmcnulty
vince944red
Had overheating problems last year probably pushed my head gasket over the edge
1 I have super clean spark plug #1 ( not yet looked at the others)
2 Misfiring when cold then clears
3 Increasingly misfire when hot at 3k revs plus
4 misfire erratic, comes and goes
5 small quantities of water going from water exp tank
Do not have
1 Oil in water exp tank
2 obvious water in oil just minor white stuff round the cap
3 white smoke from exhaust
I was hoping it was the central exhaust silencer as this has disintegrated internally recently but I guess not, the clean spark plug sort of says it has to be - steam cleaned to perfection its a textbook light brown and looks brand new?
Looks like i'm in for some DIY as I've spent too much on it recently at the garage. Anyone know what a head skim costs?
Copperman05
Edd
vince944red
DivineE
ORIGINAL: vince944red
er yes I should have said super clean spark plug in the light brown colour just as if it had come out of a handbook of what a perfect spark plug should look like with the correct mixture. I'm going to look at the others but by clean I mean clean not new out of the box!
That is confusing to read?! Steam cleaned = v.bad, light coating of undisturbed brown power type stuff = v.good
I'm surprised you've no oily film in the header tank or build up on the cap? That's usually a pretty reliable early sign on 944's. Also its almost always cylinder 4 that fails first not #1. Maybe it's buggered a valve or something?
