Have you carried out a Quirky Modification...what is it?
- Thread starter MarkK
Kongsodoken
wired into the rear wiper switch - turn on the rear wiper ( deleted) car went faster . Used to make me laugh but its removed now
Similar, but because I'm a stupid manchild I fitted a red missile switch that illuminates when flicked.Back in early days I had a switchable boost controller
MarkK
Well-known member
? ?Similar, but because I'm a stupid manchild I fitted a red misslile switch that illuminates when flicked.
scam75
Well-known member
I had one of them in one of my crazy Escort RS Turbos. Never failed to amuse me!
Cabriolet is standard - other than covers over fog/driving lights, an ancient boost bleed valve and wheels - Cup 1 (silver) or cup 2 (black) 17s
Tony
scam75
Well-known member
Did fancy fitting a duck caller or Kazoo 'teed' into a boost line with an adjustable valve so I could 'quack' if boost went over the pre set limit - this was after my boost controller sprang a leak in the monitor line and gave me over 30PSi and wheel spin on a cold damp A30 in 4th gear....
That's a good idea. Over the years I've went into unlimited boost mode via a WG diaphragm failure, a failed manual boost controller and the boost line popping off at the banjo bolt. I think 28psi was the most I saw...............
scam75
Well-known member
Amateurs - come back when you can see pistons from underneath the car and then tell me you know about “too much boost”![]()
You win! Just as well my wee standard turbo doesn't have the puff to explode my engine or I'd be on rebuild number 4.............. ?
blade7
Well-known member
I reckon my standard turbo could surge to well over 20 lbs boost, not a good idea with standard injectors though.You win! Just as well my wee standard turbo doesn't have the puff to explode my engine or I'd be on rebuild number 4.............. ?
PSH
How much boost was that then??Amateurs - come back when you can see pistons from underneath the car and then tell me you know about “too much boost”![]()
The gauge only goes up to about 35psi and it was pinned to the maximum. Probably would’ve been fine were it not for the fact that there was only enough fuel for 25psi of boost so it went crazy lean and number 1 piston jammed at TDC.How much boost was that then??
