ORIGINAL: sawood12
I think my car already has these fitted. I think you can see them in my pre-big black install photo attached below....
Yes thats the ones, they take air straight through the front bumper and I am guessing they are more effective than the 968 scoops which just stick out a little underneath.
I used to wax lyrical about how good M030 brakes were [8|] and I think it's because of those ducts, plus the fact that I had flexi ducting from the duct straight to the back of the brake disk. Scott, I still believe I had plain and simple brake fade due to boiling the fluid but Jon will strip everything down when the car comes back from the bodyshop and replace the master cylinder as well for good measure whilst installing the big blacks and Castrol SRF fluid (and a ruddy great anchor in the boot, with the parachute)
Foolishly I removed my flexi ducting when I fitted my new track wheels as I noticed they were fraying (after three years), and because I now had PF97 pads fitted, uprated brake fluid and was only running at 12psi boost before the car went down to Jons I thought it would be fine. Hindsight is truly wonderful [
