Hardtop 986 fitment
- Thread starter Guest
JCB..
Non-member
ORIGINAL: mistasmiff
Can you adjust the hardtop on a 986 boxster?, the gap at the rear looked quite wide or is that how they are ?
There is a small amount of adjustment and the gap does look big normally but it should be filled by the seal.
I found some more info in the manual - you have email........ORIGINAL: mistasmiff
How do you adjust it ?, I can fit my fingers in the gap [&:]
Black80XSA
I picked up the car to day and the passenger side rear of the hardtop has a slightly bigger gap, the drivers side looks spot on. I tried removing it and pushing it down on the passenger side to see if it sits down better but it does'nt.[
I think a trip to a specialist to make a slight adjustment is called for ..[
JCB..
Non-member
..actually it doesn't ...
I picked up the car to day and the passenger side rear of the hardtop has a slightly bigger gap, the drivers side looks spot on. I tried removing it and pushing it down on the passenger side to see if it sits down better but it does'nt.[]
I think a trip to a specialist to make a slight adjustment is called for ..[]
Sounds like the pivot pin lock may not be fitted correctly - that's the bit where the latching lever that is on the hardtop fits into. I can't see that there is any adjustment on the latching lever itself.
Is the hardtop straight i.e. not distorted?
ORIGINAL: JCB..
Well I went to my local Porsche Dealer and the head of servicing said basically that this is a known problem although not common and that he has seen this before, a simple adjustment is all that is required. [
He cheekly then said that he would do it FOC if I booked my car in for a service which it is in need of. I'm still not sure which service is needed so i'll be down there again tommorow.
..managed to blag a free key ring too ....
