Sandspider
Hi all
It's that evil time of year when the MOT is due. I've booked the car in on Saturday (thinking that all was well) but took her out today and had a quick check of various things, and it takes 10 clicks to really lock my handbrake on. (This is requiried to hold the car on my drive, which is very steep). When it's been pulled to 10 clicks, it doesn't really have any spare tension left - I can't get more than 10 clicks out of it. I assume this is an MOT failure...?
However, the handbrake pads and shoes were replaced 4 or 5 months ago when they failed on me as I was driving. (Retaining nut broke and the brakes were forced on) I took the car back for adjustment about a month after the replacement as I thought there was too much pulling required to really get the brake on hard, but the garage bloke adjusted the handbrake through the hole in the wheel hubs and said they were as tight as they could be. I had a tweak of the adjustment cable where it joins the brake lever, but it didn't seem to make much difference.
Is there anything else I can do to try and sort this? Or will I pass the MOT as long as the handbrake holds the car? (My drive is steep - in normal driving, 6 or so clicks is more than enough to hold the car stationary). And finally, do I need to take the wheels off to access the adjusment holes in the hubs? (I assume yes but I'm hoping no as it's bloody cold out there!)
Thanks in advance for any help, I really need it to pass first time this time!
Cheers,
Giles
Cheers,
Giles
